ORIGINAL: av8tor1977
Lastly, what we have here is a proven combination that works. If you would like to try something else, whether it's the fuel mix, ignition source, additives, other fuels, or whatever, please do so, and let us know how it works out. But if you just want something that we all know works, then use the proven combination. Then if you have problems we can try to help because we will be on proven and experienced "ground".
This is the last time I will make this comment: All the major fuel manufacturers make the 10 percent oil, 10 percent nitro fuel mix. If you don't believe me, do a web search and find out for yourself. Your hobby shop may or may not want to order it for you. You may or may not have to pay a hazmat fee, and/or buy a four gallon case. If you do have to buy a case, the worst that can happen is that if you don't like Gas/Glow, you have some fuel you can add oil to and fly in any glow plane. Once again, if you can't find it, another solution is to buy easily available 20/20 fuel, and cut it in half with pure methanol from a speed shop or racing go kart shop.
Have fun,
AV8TOR
I do keep trying to tell them....
AV8TOR
