RE: H9 Quality!!!!!
darock... Flyguy IS NOT bashing.... merely asking....
I work at the LHS that Flyguy uses and these errors are building and quality errors....not shipping......
we are on the THIRD set of wings with the same issue.... If Flyguy is just unlucky... fine, but with this model... there has been a few issues...
Thats all.....
I too have had great luck with Hanger 9 products.... this is just a open forum/heads up as the parts that Flyguy received looked PERFECT on the outside... but if you look carefully inside the wing, you will see the broken ribs.... almost as if they were broken during the build and just covered over....
I hope this isn't the case
Here is to hoping that this is an isolated case
