Starting point ????????????????
thats where I have run my SS nelson Q40s for the past 5 years
22,000 on that prop, is quite a bit low. Either you have a leak somewhere between the fuel tank and the engine, or the motor is just tired. Have you tried other APC props with the same numbers stamped on it? They do vary a little....
