RCU Forums - View Single Post - effect of prop pitch on efficiency
Old 05-30-2007 | 09:53 PM
B.L.E.'s Avatar
B.L.E.
Default RE: effect of prop pitch on efficiency
ORIGINAL: Jim Thomerson
Didn't know you could move masses of air with 0 work.
I never said that it took zero energy to spin the prop. A prop is doing zero work in a static thrust situation because the thrust is not moving the load. Work is force X distance. Power is force X speed. If the planes speed is zero, than the power delivered to the plane is zero. All the force in the world X zero equals zero.
It's like a car that is not moving at a red light, it is getting zero miles per gallon. A humongus Hum-Vee and a 50 cc motorcycle both get zero miles per gallon while stopped at a red light but one is still burning a lot less fuel than the other.
