Widebody 60 Equipment
PatternFly
Thanks, I was thinking of putting two DS 811's on the Elevator and wanted to fix the two on the back just below the stab, now the problem is that fuse is two narrow to accomodate the two in line on the opposite side. Do you have any suggestions.
2nd does anyone have the pictures of their widebody servo tray setup and fuel tank.
Also with a 91fx installed without a fuel pump can i pull the tank behind.. will it effect the performance. ?
regards
aziz
