Widebody 60 Equipment
DS8411 Digital Servo Specifications
Torque: 155 oz./in.
Speed: .18 sec/60¡Æ
Sweep: .16 sec/60¡Æ
Weight: 2.03 oz.
AABearing: Dual
Motor: Coreless Hi Torque
Uses: 1.20 Size to 40% Giant Scale Airplanes
8231 Ultra-Precision Digital Servo Specifications
Torque: 88 oz./in.
Speed: .22 sec/60¡Æ
Weight: 1.73 oz.
AABearing: Dual
Idle: 11 ma
Motor: Coreless
Uses: pricession pattern and jet airplanes, collective and rudder on helicopters
Here are the spec of the 8231 & 8411.
Personally, I use 8231 on Elevator with MK bellcrank, 8411 on rudder in my Pilot BeatOn90.
For Widebody, I plan to use 8411SAs for elevator and rudder. I know it is overkill, but I already have them. You can get by with 8231s just fine, but I dont have spare 8231s.
I try to use stronger servo for larger control area, so I prefer 8411SA on elevator because of the actual elevator size larger than the rudder.
I have no idea about 8425 so can not comment on it.
If I choose, I would use the setup on #46
As Thomasr said in previous posting, you don't need a 811 on throttle. Just use whatever you have that are good enough for the plane. Try to keep the overall weight lower.
