RCU Forums - View Single Post - Widebody 60 Equipment
Old 04-06-2003 | 01:02 PM
  #67
snsmith
Default Widebody 60 Equipment
Sounds good, although unless you just have a DS-811 laying around collecting dust, I'd put something lighter and less expensive on throttle. I'm using a Hitec HS-81 on my throttle.
FWIW, this is the setup I'm finishing up:
YS FZ91
12-14oz tank (got three, trying to find the biggest that will fit over the CG)
JR 649S PCM receiver
2 JR 9411 ailerons
1 JR 8417 elevator with dual CF pushrod setup
1 Futaba 9402 rudder, pull-pull with a tiller bar
Hitec HS-81 throttle
1100mAh battery
Should be sweet...
