RCU Forums - View Single Post - Widebody 60 Equipment
Old 04-07-2003 | 12:17 AM
  #73
PatternFlyer
My Feedback: (182)
Default Widebody 60 Equipment
Brian,
Which sequece are you are you talking about? Intermediate? or Advanced? Masters?
I think you are better off with 14oz. 16oz kinda sounds too big. Anyway it's up to you. If you don't have a pump, you better stick to the location right behind the firewall.
Also, the fuse doubler is balsa on my kit. Were yours also had balsa in it? Fuse doubler in my kit is not very strong.
I think we have to cut out the servo location. I could not find any marking for that. The instruction only says where to make the hole.
Have you talked to the guys who you bought the kit from?
My kit had slight wing damage because of the landing gear. Outside box is fine, so it looks like the shake during shipping caused the damage.
Since I am going to use pump with 91SX, I will probably build a glass canopy out of the original canopy and paint it so the tank can go on the CG.
Which engine mount are you using?
