RCU Forums - View Single Post - Calling Electronic Wizards... Dual Glow Plug hookup
Old 05-31-2007 | 09:10 AM
captinjohn
Default RE: Calling Electronic Wizards... Dual Glow Plug hookup
If you are going to lite two 3 volt lamps in series ...you need one 6 volt battery. It is the same with glow plugs. 2 x 1.5 = 3 Volts. Also the polarity does not matter to plugs or lamps. I use 2 power panels on my twin and can regulate the amps and glow on each glow plug. Capt,n
