RE: Gas Engine Idle Question
You're correct about the flywheel effect.
You should not start an engine like this without some kind of load on it--magneto--prop--clutch assembly--chain etc.. But if you were to take the prop off and start it--you'd be hard pressed to get an idle under 3000RPM. Without a flywheel to keep the inertia and momentum going--it would have to idle very fast to overcome the compression.
