RCU Forums - View Single Post - WH 260 Help
Thread: WH 260 Help
Old 05-31-2007 | 07:58 PM
  #47
johnflys1
Default RE: WH 260 Help
The incidence meter says the leading edge of the horizontal is to high. It is one increment on the meter. I don't know if that is a degree. It is about 1/2 bubble off. That is what is causing the dive problem or at least most of it. I am wondering if I can loosen the attach bolt holes at adjust it down any. It could induce a twist but it is worth a try. Both sides are the close to the same, but the right side is worse than the left. It would be an easy adjustment with only one tube but with two it becomes more difficult. Does anyone have anything else to try without taking the tube sleeves out if I can't adjust with the bolt holes? John
