More on Fuel 10/10
http://www.sigmfg.com/cgi-bin/dpsmar...FV4.html?E+Sig
CHAMPION "BIG BORE"
For use in larger 2-cycle glow engines where the engine manufacturer recommends a fuel with less oil (Super Tigre, Tartan, Bully, etc.) The total oil content of this blend is 12% (1/2 castor oil, 1/2 Klotz). The lower oil content can improve the idle and throttle transition of these large, slow turning engines. This fuel should not be used in any .010 - 1.00 cu.in. 2-stroke glow engines or in 4-stroke glow engines of any size. If in doubt, check with your engine manufacturer before running this fuel in your engine.
TIGER Blend Fuel
A special blend of castor and Klotz Synthetic lubricant especially made for large Super Tigre Engines.
10% Nitromethane
10% Blended Oils
Product Code Description Price Type Order
Quantity
SIGCF310 SIG BIG BORE FUEL 10% [GAL]
FLAMMABLE EACH $12.99
SIGCF602 SIG 10% TIGER BLEND [GAL]
FLAMMABLE EACH $13.79
