RE: Yellow Aircraft P-40 Engine?
What's the diameter on that Solo? I barely have ground clearance with the 24x12 Mejzlik .. as you know the gear "squat" down to the stiffer spring end point as soon as the airplane is sitting on them... would be cool if it can be made to work, tho.
