RCU Forums - View Single Post - DA 50 Running Problems
Old 06-01-2007 | 12:13 AM
Kevin Greene's Avatar
Kevin Greene
My Feedback: (85)
Default RE: DA 50 Running Problems
ORIGINAL: dick Hanson
What happens when the reeds open :
the low pressure created which opens the reeds creates a low pressure in the carb .
the carb determines the mix (ratio of air to liquid gasoline )
IF--the reed opening time is short or long - the carb does not know or care -
IF------ the low pressure (signal)is very strong or weak - the carb does care .
reed stiffness will affect power available but the fuel to air mixture should not be affected.an overly strong low pressure (signal) should increase fuel flow but that would indicate that the carb size (basic venturii size) is too small.
So far --I can't find any real difference in top end needle settings of 201/76 -which would indicate that they both flow the same .
The 201 will choke more easily than the 76-at least on the ZDZ40/40 engines and it has more dischage orifices (3 vs 1) for low and you could say midrange flow.
IF there is any real difference it is in the high speed jet and frankly I can't see it if it exists .
someone must know if there is a difference in this part -that is my question.
the cover plate on the pump side are different we know that -
the zdz carb has a drilled tran sfer passage NOT found in the carbs using external pulse line.
so I can only note that the low speed delivery on th 201 is different -as a difference between the two carbs .
I simply don't know more about what Walbro may/may not have done in the high speed circuit.
I see what you are saying---I was thinking that if the reed opening was too short that the engine wouldn't get enough fuel..Your explanation tells me that although the engine may not get enough fuel, it would also not get enough air by the same ratio--Hence the A/F ratio wouldn't be affected---Right????
One of the modelers here bolted on a carb from a DL50 to his DA50 and claimed that he could richen up the mixture.....Where as with the stock DA50 carb the mixture couldn't be richened --The venturi on the DL50 carb is slightly smaller, thus allowing a stronger vacuum though the carb---Possibly allowing the engine to draw more fuel from the carb...What are your thoughts on this??
Kevin
