RCU Forums - View Single Post - Designing for ultimate speed
Old 06-01-2007 | 05:13 AM
The Raven's Avatar
The Raven
Default RE: Designing for ultimate speed
ORIGINAL: Mike Connor
You should post this in the "Extream Speed Prop Plane" forum. A lot of the talk is about normal fast airplanes but if you look around over there you can get info on the World record holders in Europe. However, the engine you have is a far cry from what the speed speed guys are using but you could break 100 mph on a Q-500 type plane.
I just realized you have been in the speed forum. There is some good info there but you may have to search for it.
Thanks, I wasn't aware of the Extreme Speed forum when I originally posted it but I did find it shortly after.
My mention of an AX was merely as a starting point. If there was a similarly affordable engine that was better suited then that would be fine.
