RE: effect of prop pitch on efficiency
How the prop interacts with the airframe can also skew the entire argument.
On my models -I have been playing with trying to get maximum prop efficiency by not restricting flow behind the prop
You don't need a Doctorate in Fluid Flow to see that any obstruction in front or behind a prop --will affect flow through the blades . On the big radial engines -this was a problem
