RE: Getting the Reciever and Plane in tact.
I don't see how it would cause interference. Unless you're running current through your pushrods, they're not generating a magnetic field to inductively couple into anything. If you ran the antenna right next to a push rod, it would block the antenna at a specific angle, but once you get an inch or more of separation, that's not even an issue. To each his own...
