RCU Forums - View Single Post - Model Tech Extra question....
Old 06-01-2007 | 12:52 PM
opjose's Avatar
opjose
Default RE: Model Tech Extra question....
Are you talking about the Model Tech Extra 330 .30 sized plane?
If so it will do fine.
I put an OS .46 LA engine into my Model Tech Extra 330 and it does just fine.
It's fairly good with a 10x6 or 10x7 prop.
The thing is a speedster though...
The cowl is quite large and you should have no problems, especially if you mount the engine at the 45 degree head down configuration they use as a default.
If I recall correctly the plane weights about 3.5 lbs and I used standard servos in it, but I MAY have used mini servos for the wings... It's been a while since I put mine together... it's still flying though...
Remember to re-inforce the gear blocks... and go for larger ( much larger ) wheels if you plan on flying off/onto grass.
