RCU Forums - View Single Post - FOX COMPOSITES Bae HAWK, Build thread
Old 06-01-2007 | 03:38 PM
  #248
jason's Avatar
jason
Default RE: FOX COMPOSITES Bae HAWK, Build thread
ORIGINAL: Chris-DC5
The model was flying in a slight shallow dive when i went to pull out there was a total lack of elevator responce and the model went into the ground.
After much thought and consideration it turns out that the Elevator servo was not powerful enough even ay 8.5kg@10mm.
The instructions say to use a 8kg servo or more so i thought that 8.5kg wouls have been good enough.
Many thanks,
Chris.
Chris, I think the 8kg servo is fine on the AMD hawk. From what I've seen it's the linkage which is the root of the problems. Thing is the standard linkage fitted to the aly joiner calls for atv's to be used and this reduces the power of the servo. The threaded rod needs extending to solve this.Ive lost count how many ive seen go in or nearly go in because of this problem.
Jason
Paul, it's Friday night and Bickley is in the morning.. Please try and show up before mid day[8D]
