RE: World Models Sky Raider Mach II
Hi,
I'm learning to fly on this plane and I'm very pleased with how it flies. Construction issues I encountered were the following:
• Covering needed to be tacked down along all seams and is still having trouble staying on
• Aileron torque rods are uneven and one side is rather tight
• No way to add foam around the fuel tank short of hacking and recovering the fuse
• Landing gear is very weak
• Tee-nut placement for wing bolts is slightly off and incorrectly angled. It's a chore to get the wing bolted on.
Not too bad for an inexpensive ARF, I suppose. If only it looked as good as it flies... [&o]
