RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 06-01-2007 | 09:19 PM
  #3255
Barrrick
Default RE: Wheeeeeeee.......... Blade CP!
RICK HERE : been a looooong time since I finished a model....but just now I have the TEST BED CESSNA ready for Maiden Flight. For the first time I run the 400 OutRunner with its 10 x 7 prop, and WOW does it put out power !!!! I can already see that this little bit of foam fluff model will have to be TAMED DOWN.... I have set it up like I used to my Pattern FLyers, with full deflections but with the DX-7 for the TX I am 100% sure that ATF and even Exponential I am guessing will be a must do...... With good results on range, duration and flyability, this is the whole equipmnt. that goes into the REX. Except for the DX7 long range tests to be done on a bigger Electric plane. NOW to set up the PRO with the BRUSHLESS and the GYRO ... ...........can't hardly wait to see the difference. And what about the CNC ? for a good upgrade ? do I need it ? am I talking about a "metallic" swash plate ? I don't even know what I talk about .....shheeesh what a dumb bunny. Need to clear the bench before I start. My daughter comes back from Italy on Monday, so I got two days for HELI BLISS..... CHEERS to all........ye Olde Phartte RICK
