RCU Forums - View Single Post - JetJoe OWNERS thread
Old 06-02-2007 | 01:32 AM
  #984
fw190pilot
Default RE: JetJoe OWNERS thread
Warwick
Are you sure gas is getting into the engine the orange gas tubing is known to kink inside front cover and shutting off gas flow (should be able to blow through line). Check that the gas line to the turbine from the solenoid is on the fitting at the far end away from the coil. If it is hooked the other way the solenoid can jam and won't allow gas flow. Make sure solenoids are plugged into fadec and not reversed.
