RE: soldering
yeah, you should realyl get them on there. They do make a big difference. Also on most brushed motors (ok all that I have seen) make sure to solder the negative lead off of the cap to the side of the motor, or solder 3 104 caps, one between the case and the positive pole, then one between the case and the negative pole, and then one between the 2 poles.
