RCU Forums - View Single Post - Sig Kougar Build
Old 06-02-2007 | 05:11 PM
  #48
jollyroger
Default RE: Sig Kougar Build
All great looking Kougars!
Subm: Looking good so far, much further than I've got with mine. So far I added lightening hole to the fuse behind the wing saddle and have to do the same with the tail feathers. I had a former come loose as it appears there was not nough epoxy. Will use Gorilla glue next.
Has anybody converted to dual aileron servos? If so, how should I attempt this? Should I sheet the wing and then route the servo bay and wire lead channel? I would use HS-85MG for the ailerons as they are quite robust for their size.
I've got so many projects on the table, I really need to concentrate on one until it is finished. So here goes.
cheers jollyroger
