RCU Forums - View Single Post - OS 46 FX puzzled
Old 03-04-2003 | 04:46 PM
mobius88
Default similar exp on 61 FX
my 61 FX used to quit all the time while it was brand new. The 61 FX is similar to the 46 FX only larger disp.
I broke it in per booklet, 2 tanks or so. Used Bisson pitts muffler.
What happened was during break-in and shortly after, it needed a lot of backpressure which the pitts did not supply.
I also had an in-line fuel filter.
The engine would start and run but would not hold idle. Then it would quit in the air.
I plugged one of the two pitts exhaust tubes and removed the inline filter (dubro).
The engine ran fine then, didnt quit and held idle.
After 10-20 flights the pitts restrictor i put in (1/4-20 set screw) fell out in flight.
Then engine liked the lesser restriction and was fully broken in, at least enough so that it ran like a champ ever since. This engine is the best I've ever owned.
Not sure if the problem would have even occurred had i started with the stock muffler, but the engine was broken in as i was planning to run - - with pitts.
