RCU Forums - View Single Post - Need secrets/tips starting tee dee 049S
Old 06-03-2007 | 12:41 AM
Remby
Default RE: Need secrets/tips starting tee dee 049S
All of the above, making a effort to visual check the glow in the glowhead. Better idea, put a fresh plug on. Also, clean the needle valve, venturi assembly as best as you can. ANY blockage can cause the trouble you are reporting.
If you have "spark', and the fuel flows right, it will fire.
