RCU Forums - View Single Post - easiest way to get into 3d flying
Old 06-03-2007 | 12:32 PM
MikeEast's Avatar
MikeEast
Default RE: easiest way to get into 3d flying
ORIGINAL: woodnears
i have read your review and seen every video of the tribute. It looks like a good plane. One concerne was the fuselage being weak, even though i will just run the evo 36 on it is it a good idea to reinforce the fuse around the wing saddle? i was going to get the pnp version are the servos in it up to par, for some serious stunts?
undefined
Well it could not hurt. You might be able to lay a little carbon fiber mat in there without adding any weight.. Just thin the epoxy 50/50 with alcohol and put it on lightly. I would do it anywhere I could from the leading to the trailing edge in the saddle.... BUT, with the EVO 36 I really dont think it is necessary unless you just happen to get a 1 off weak fuse.
