dp120
I mounted both elevator and rudder to the outside of the large center cutout just like in the picture, not sure what's going on here, the cables that rub on the bulkheadare the elevator up cables. i took the servo out cause I was considering raising it up, I would have to raise the servo atleast one inch to keep the cables from rubbing on the bulkhead. On my cutouts on the fueslage i had to cut the cutouts for the up elevator, down pull and rudder were already cutout, I cut it out the distance it said in the book 1/4 inch above the elevator stab. I see no way to keep them from rubbing considering feeding a nylon casing for these two wires.
Any more input I would greatly appreciate it.
Scott
