RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 06-03-2007 | 08:17 PM
  #6008
rclement's Avatar
rclement
Default RE: U-Can-Do 3d 46?
Hi Greg, Here's what I use for fueling. I have 2 clunks and one of them comes through the cowl to a fuel dot. I don't bother with the Dubro fuel valve since I'm not always sure that it isn't leaking air or not.
I usually don't use a remote glow conection on the plane. I just usually cut a hole in the bottom of the cowl and attach the driver that way. But with the Do I just recently built on put on this Dubro one and can say I'm sure glad I did. It attaches securely and is much easier to use than trying to reach under the cowl. Here's the one I use now....... [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXD693&P=7]dubro glow connector[/link] I put it on the side of the fuse above the right wing and it's very easy to install and use.
