RCU Forums - View Single Post - ASIAN skymaster PROBLEMS
Old 06-03-2007 | 10:06 PM
warbird_1's Avatar
warbird_1
My Feedback: (61)
Default RE: ASIAN skymaster PROBLEMS
ORIGINAL: lov2flyrc
Steve,
With Skymaster changing factories almost as often as I change underwear, chances of you getting paint that matches is slim. If you take a color sample to your local automotive paint shop, they can color match in both single a dual stage paint. Only disadvantage is you will have to buy a pint minimum. They can even put the matched paint into a spray can for you if desired....
Todd
todds right, when i need paint i take the plane right to the auto paint supply store and they can scan it with a handheld scanner and give you a very close match .
