RCU Forums - View Single Post - Mixing for KE help.
Old 06-03-2007 | 10:31 PM
tIANci's Avatar
tIANci
Default RE: Mixing for KE help.
Backwing - I used to think of that too ... so it means I need a to be able to switch the mix on and off, recently in Fly RC magazine they stated that if you plane needs mix in KE then you will need it each time you execute a manuever with the rudder, seemingly its very obvious. Hence, if Fly RC is correct then there is no need to use a switch. BTW, what happens when you use the rudder in a KE, is it only a pitch issue? If so you can always play with the CG to sort it out before you mix it.
