RCU Forums - View Single Post - 85 in Val with removable scale surfaces
Old 06-03-2007 | 10:38 PM
Baldeagle
My Feedback: (7)
Default RE: 85 in Val with removable scale surfaces
I mounted the wing to the fush with wax paper between them. Then glued 1/32 ply to the fush. Nexed I added 1/2 soft balsa for deviders and shaped to form the fairing with 80 grit sandpaper glued to 1 in PVC. After shapping I glued 1/16 balsa to the top.
The wing and fush is almost done. Working on the landing gear now.
ID:	697117   Click image for larger version
