RE: tip stalling issues
dbacque, when i flew the plane last (great planes patty wagstaff) I did stall her out up high to see if on wing was constantly dropping. found that no wing in particular was dropping. On twisting the wing, I’m not sure i can because the wing is sheeted with wood. What do you think? ill be out on Saturday an try that inverted pass and see what i find.
3dd- ive heard that dose help dropping both ailerons.. Essentially making flaperions. just to make sure I’m catching what your referring to is lower them not raise, because raising them in my mind would kill lift making an air brake.
ill let you guys know what i find on Saturday
thanks--
chris
