RE: servos
Hi Austin -
Here's what I would to do troubleshoot.
Disconnect the motor and all but one servo. Check to be sure the servo is plugged in correctly. If the plug is upside down, the servo won't work. Try all the servos one at a time, being sure you've plugged them in correctly.
If the servos still don't work, you might have a problem with the ESC/RX.
- Jeff
