RCU Forums - View Single Post - sts questions
Old 06-04-2007 | 02:47 AM
  #65
sputnikxxx's Avatar
sputnikxxx
Default RE: sts questions
I have a question about the mk II I got through all the 6 to 8 idle tanks per instructions... I then thought I would drive it around a little real lightly.. but when I tried and would give it throttle.... it acted like it would want to bog.... I know the settings are usually rich from the getgo for breakin procedure but ive never had a motor so rich that had so little power that it would not even hardly move?.... I tried leaning it out a bit on the low speed needle as it was shooting thick smoke just at idle...
Is this should like the problem or does this seem like a clutch problem?... I did get it to open up once and start to take off but then I was out of fuel.... and im done workin on it today so I will figure it out tomorrow
