RE: Evolution 116CC starting
MVVS at one time had a choke plate without small hole in it. In the instructions, they warned not to run with the choke closed. Some folks use the choke to stop an engine, and for this paticular carb/engine combo that was not a good idea, because it might damage the reeds.
For starting the later line of engines, there is nothing wrong with the standard closed choke starting procedure.
