RE: Throttle dies repetively
Sounds like signal loss or a bad batter connection. Could also be a bad battery. Check your connectors for any corrosion or looseness. If you wiggle the connection and reset the heli, then you found your problem. May just need to tighten up the connection. If you still cannot get it to work properly you can return it here to MRC for service.
Jeff
