power lines and radio signals
just read what you said about Air Circuit Breakers. Where are those located? I know sometimes that a transformer nearby will blow an internal fuse and the COOP guy has to come out to replace it before power will come back on.
ACB's are located at the substation (sub). 4KV and 12KV transformers have fuses located near them. A small, quick short will not generally blow the hard fuses in the line, but may trip the circuit breaker at the sub. Line fuses require a hard short for three complete cycles, circuit breakers only one.
Things may have changed a little since I was a power engineer at the PG&E research facility in San Ramon, CA, but power is power, and it has been handled almost the same since the early 1900's.
