RE: Fuel Can Fitting Set
I use 2 brass tubes sealed with clear silicone; The filler line has a brass tube on the end; the vent has a piece of fuel tube into which I stick the brass filler tube when not using. I have fuel that sits all winter like this with no problem. I don't think a little bit of moisture is as big a worry as some think.
