RE: Fuel Can Fitting Set
it will give you years of service mine is 4yrs old and going strong just check the lock nuts once and a while they loosen up once in a while.
as for fuel going bad it seals the can fine the enemy of fuel is cold, don't let your gas freeze.
opening, closing, and switching caps, will get you nothing but dirt in your fuel.
you don't want that.
