RE: RCM Eagle V
The data terminal is left unplugged and out of the plane, it is typically only used for initial setup of the turbine. Once you are happy with the startup of the turbine, just leave it unplugged. Once you fly and perhaps want to change one of the settings, then it can be plugged in and the setting(s) changed but the WREN unit usually runs fine with the factory default settings!
