RE: prop balancing
Or you can use Minwax PU, spray the light tip, or just dip the light tip in a can of PU and let dry-only downside is it takes longer to dry but its fuelproof. Prep the same as stated above. If you want colors, use the old timey Rustoleum enamel paint.
