1/16 off
Ok well i bolted on the wing of my p-47 thunder bolt measured twice and glued on the belly pan, now as I prepare to install the vertical stabilizer i noticed the wings have a 1/16 of an inch difference from wing tip to the end of the fuselage. should I ignore the 1/16 difference and adjust the stabilizer to be equally spaced or should I re-do the belly pan to make everything perfectly aligned.
