RE: incidence problem
Hay Don, sorry it took so long to get back to you about this problem. Here is what we found , a right wing warp that you cant see sighting down the wing but if you start inboard with the incidence meter and go out you will have 1/2 degree difference in root and tip increasing as you go out . So Everette and I have done a lot of adjusting and have gotten the ailerons in the boxes and have gotten the plane to lock on pretty well , it is very soft and friendly to fly and will pass most but not all of the basic trim test ,so far I have only flown it about 30 times so it may get better as we go and tinker with it. For Sportsman it will do just fine until I can pick up something better.
Thanks For your time, you and your teaching and information on this form and on the DVD have greatly improved my flying.
Thanks Kirk
PS We would love to come to your area do you have any contest that you will be at within a reasonable drive from Nashville?
