RE: TMPro Extra 260 P46 Build Thread
Now for the fuse. I cut the holes for the servos and for everything else on the fuse. I notice when I cut the holes where you put the wires through there was string. The string is for to pull the servo extensions through. I had problems with the Katanas pulling them through. But with this one it was easy! They gave you enough room in this one to pull both wires through. As you might notice one of the holes I cut didnt come out that pretty. I forgot to bring my iron down to the lake to fix it up. After installing the servos and the extensions I went through and glued the horizontal and vertical tail along with the rudder and elevators. Plus I installed the tail wheel.
As for the landing gear I put the wheelpants on to show how they went on. But I took them right back off before I installed the landing gear to the plane. They look great on the plane but can be a pain in grass sometimes. But they are nice to have because they do make the plane look great. The wire landing gear for this model is a lot better than the ones that the Katanas were supplied with. Hopefully these will last longer!
