RE: anybody got spare wings
awesome I will give john a call.
My fues idea is simple. It uses omp's old construction method where you have a foam core sheeted fues. I want to try using 9mm depron as my foam core, stiffened with CF in certain areas then sheet with 1/32nd competition grade balsa. Tail feathers will also be depron based. I will use a one piece wing to keep it simple. One servo set up pull pull on the rudder, one on the elevator, one on each wing and an 81 on throttle.
Maybe someone has tried this and failed??? If so let me know your experiences
