DAVE PATRICK SUPER CUB QUESTION
I am just looking for a little confirmation on the ailerons and flap install. To get the correct throws as stated in the manual I have a bit of a gap between the TE and the control surface. The aileron trailing edge sits back about 1/8" from being flush at the end near the tip of the wing. Is this the way most of you ended up on your ailerons/flaps?
Dan
