RCU Forums - View Single Post - CP Gyro Issue
Old 06-07-2007 | 01:12 AM
mrasmm
Default RE: CP Gyro Issue
hrm, that's not so good. The front one is the gain for the gyro on the 3 in 1. The proportional needs to be set without any power. that might all be info you know though.... I can't really see on your pic, but is the gain turned nearly all the way up?
Unplug the battery and turn the gain all the way down and the proportional about half. Arm the heli and see how it does, unplug the battery and make the adjustment to the proportional until it gets where you want it, then after that you can adjust the gain with the battery plugged in. Just adjust it until the tail wags a bit, and then turn it back down enough so that it doesn't wag =)
