Balancing a prop.
Yes, thsat's what mine did. Did you use the plastic disks that came with it?
I lost mine and had that problem, so I just made more. Also, when you have the prop close, or, you think it is balanced, turn the pull the rod away when turning, and re-check. One more thing, did you adjust the magnets so the rod only makes contact on one side?
Jetts
