The area should be about the same following the area rule. The center cone takes up some space so the outer cone must make up for it with a larger diameter opening. You can squeeze the area on either type and get more thrust and higher temps.
Thanks Sara for making it appear I know what I'm talking about
You know more about it than me Paul. I just have a little knack for understanding SOME things
